First post, by thepolish
My original msi board died (bad caps) and I attempted but failed to recap it. I bought a P5PE-VM on eBay, but it also had bad caps. I replaced them but the pci bus is doing some glitchy things, and the agp slot cap is bulging again, even with the new Panasonic cap installed there.
I wanted to pick up the 775i65g but it's out of production, so I'm looking for advice on another 775 board for my p4 windows 98. Machine. I'm most worried about W98 support. I run xp and 98 on it but mostly 98. Agp is a must as I swap between a voodoo 3 2000 pci and a Radeon 9500 agp card.
I want to stick with the P4 I have (forget which one exactly, but it's case badged and everything for it, so looks I guess).
Thoughts? Anywhere anyone is aware of that I can still get that asrock board maybe?
Thanks,
Zach
