First post, by gladders
Hello, yes, it's me again.
So I have this BX-6, which I covet for its 440BX chipset, as you all likely know. I recently moved it to a new case, but then it kept freezing on the memory check at boot. Turns out it was a modem card that I was just using to fill an empty slot, so I took it out.
Now I can't get it to POST properly. Upon resetting the CMOS, it boots defaults, but when changing settings in BIOS, I get problems.
It's a 450MHz Pentium III processor, but on default the BIOS reports it as 300Mhz. So I change that, and I set the IDE detection settings.
Once I do that, it simply refuses to POST. Blank screen.
I have resetted it tons of times, and tried to let it boot on just 300Mhz settings. It stops after the memory check reporting a CMOS settings error.
Help?
Reply 1 of 8, by H3nrik V!
gladders wrote:
Hello, yes, it's me again. […]
Help?
Two things come to my mind:
1. Bad capacitors - they can explain almost ALL weird behavior
2. CMOS battery dead - if just on the threshold, it might produce weird results. For all it's worth, it is pretty easy and affordable to give it a try?
