First post, by Almoststew1990
I was setting up a system to play XP games on the Pentium 4 but unfortunately the board doesn't seem stable. My Plan B is to use my Socket 939 Athlon 64 Venice 3200+ CPU.
In terms of CPU (and I suppose memory) speeds, is the athlon going to be similar in performance? I know the athlons were ahead clock for clock but 3.4GHz is a lot of raw speed... Also hyperthreading
Reply 1 of 13, by Roman555
You can compare performance:
https://cpu.userbenchmark.com/Compare/AMD-Ath … GHz/m7063vsm293
I would pick AMD-Athlon-64-3200 - it has lower power consumption. I think one-core CPU is enough for Win XP period games.
But used motherboards, based on nForce chipsets of that period, often become unreliable.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 2 of 13, by The Serpent Rider
Depends. Prescott is slower in general, but Prescott G1 can be overclocked pretty far (4ghz and more).
Reply 3 of 13, by Almoststew1990
*looks awkwardly at my nforce 4 based S939 motherboard that I was hoping would be more reliable than the Intel based S478 one*
Reply 6 of 13, by mothergoose729
An athlon 3200+ will perform pretty much the same as the prescott. The power consumption on that chip is pretty low - it is a 90nm variant. You can probably get a very decent overclock out of it even with a stock cooler.
If you want more performance, you can also get a 4000+, or a 3500+ venice or manchester core which are only about 10 more watts.
I have never had trouble with 939 sockets in XP.
Reply 7 of 13, by BinaryDemon
Don’t most socket 939 also support a few dual cores, if you were looking for an improved XP experience.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 8 of 13, by data9791
Manchester and Toledo Athlon 64 X2's come in that socket, but it's all AM2 after that I think.
Reply 9 of 13, by The Serpent Rider
What's wrong with nForce 4?
Prone to die often due to manufacturing quirks of that time. Also bad for legacy support.
Reply 11 of 13, by gdjacobs
You might be thinking of the K8T800. KT880 is the penultimate VIA socket A chipset and interfaces using the EV6 bus instead of Hypertransport.
