First post, by buckeye
Thinking about jumping on one these for sale to tinker with but keep reading about how the cpu/case fans
have proprietary connections on the mobo. Not good as I wanted to install a new cpu cooler, can you Dell
gurus out there confirm this?
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 2 of 2, by Merovign
You can just use the plug from the stock fans to make adapters, if you're willing to sacrifice the original fans.
Personally I'd put a note with the original fans, if I stored them, with the pinout in case I wanted to re-use them later.
Similar problem with things like the early Dell Poweredge desktops (like my 830) with a single very loud funky PWM fan cooling the whole system.
*Too* *many* *things*!
