First post, by feltel
For my 2nd PS/2 I recently aquired a 270 MB SCSI drive (IBM-labeled Quantum LPS, https://stason.org/TULARC/pc/hard-drives-hdd/ … L-SCSI2-SE.html). The drive was jumpered to ID2, but to be bootable in an PS/2 it has to be at ID6 as far as I understand it.
Unfortunatley one of those super tiny jumpers was missing so I only was able to jumper it to ID6 by removing the jumper from the PO position. By default the jumper is being set and enables the "enable parity check" function. While the is jumper removed I did not noticed any difference and I successfully could make it boot in my PS/2. Also the SCSI drive check within the reference disk/adv diagnostics disk is without any errors.
As far as I understand it should have no consequences, but for safety's sake I want to ask if someone has an opinion on this.
