First post, by Miphee
I got this computer with the TCM-200A socket 7 motherboard that is incompatible with the standard socket 7 Pentium CPUs.
The seller didn't know this and put a standard socket 7 CPU in it so now it smells worse than my wife's cooking: burnt smell everywhere. It looks flawless though. I need the Cyrix MediaGX CPU pinout to compare it with the Pentium pinout and start looking for the possible culprit.
I don't have a MediaGX or compatible CPU right now to test it but it's on the way. The seller claims that nothing was burning/smoking when he tested it, but let's just say that I don't really trust him.
I bought it anyway as a toy to practice my fault detecting and SMD soldering skills.
There could be nothing wrong with it but the smell is a dead giveaway... or it was rescued from a burning house. The smell is so strong that I can smell it across the room.
I gave it to the wife and she says the smell is the strongest in the CPU socket area.
Maybe you can spot something I couldn't but the pinout would be important to start.
Thanks.
(Or maybe it's the little PSU, impossible to tell. I'll test that tomorrow.)
    1.68 MiB
    1.74 MiB
    1.89 MiB
    1.62 MiB
Reply 1 of 9, by Miphee
More pictures.
    1.63 MiB
    1.87 MiB
Reply 2 of 9, by red-ray
See the attached
    gxmdb_v20.pdf
    1.78 MiB
    73 downloads
    Cyrix Media GX Data Book
Reply 4 of 9, by cyclone3d
Could be that it just fried the CPU that was installed in it.. and maybe/probably in the process made some of the cpu socket pins so hot that it melted the socket plastic a bit.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 9, by Miphee
Could be. I checked it thoroughly under magnifying glass but found no burns or discolorations. It looks fine so moving onto the PSU.
I already see discolorations, burns on the negative supply transformer and signs of soldering/solder overheating. I'm 90% sure that the source of the smell is the transformer. Needs load testing and temp check on the parts under full load. It's a very small case with no ventillation, the PSU has no fan and heat transfer between the power switch transistor and the small heatsink is poor. A generally flawed design bound to fail.
https://www.parkytowers.me.uk/thin/esesix/wlgx01/
    651.05 KiB
    1.92 MiB
    1.97 MiB
    1.79 MiB
Reply 6 of 9, by Miphee
Is the green wire the PS_ON? It is called CTL on the power supply's PCB.
    523.15 KiB
Reply 7 of 9, by Miphee
"ONCTL Output
On/Off Control for the RTC’s Advanced Power Control (APC) –
This signal indicates to the main power supply to turn on power.
ONCTL is an open-drain output signal that is powered by VCCH."
Is it the same as the green wire PS_ON output on ATX power supplies?
Reply 8 of 9, by Tiido
Grounding the signal will turn the power supply on so on that regard it is functioning like ATX PSUs.
Reply 9 of 9, by Miphee
Thank you, worked like a charm.
Here is the BIOS dump if anyone needs it.
