First post, by walterg74
Hey folks,
I have been using a gotek for a while, and while it’s nice and all, when you start setting up “the” flash drive to have all your install disks on, games, etc, the number starts to add up quickly.
So it’s a real downer that while the device itself supports up to 1000 slots, and you can even format those slots with just a few buttons, that the software that comes with these only manages up to 100 slots...
So is there any alternative software or something that would allow you to easily copy stuff to all slots from your files on a pc..?
Alternatively, If you go the “flash with flashfloppy firmware” route, how does that work? Does it just cycle through ALL files then? And if so must they be in img format at that point? Also I assume if that’s the case you need a display to know which file you’re selecting?
