First post, by massimo233
So, recently I picked up this old 386 DX-40, had been tinkering around with it for a while, installed Windows 3.1, and enjoyed going through all my 5 inch floppies back in the day and seeing what files and whatnot were on there. But at one point I had a hardware issue so I decided to reinstall DOS 6.22, which is where things started getting weird. First off, my B: drive (5 1/4 floppy) was no longer accessible, well, it was, but it will only show the contents of any disk i have in drive A: . Even if there is 5 inch floppy in the B: drive I am able to switch to it, but again its always the files from the 3.5" drive! the only time it won't read at all is when there is nothing in the A: drive. I've checked all my bios/cmos settings and everything is setup correctly and there was never a problem before I had suddenly updated. One thing that did change though is before I would switch to a drive, it would ask me to insert a disk then press enter. before that started occuring this didn't happen. anyone that would have any tips or help to offer would be much appreciated, and i am sorry if this is the wrong forum!
cheers,
max
