First post, by makeshiftuk
Hi gents,
First post here, hope I'm in the right section...
I'm trying to breathe some life into an old Slot1 rig from '98 - and at it's heart, a GA-BX2000+ motherboard. I've recently sourced an SL4BS P3 1GHz (133MHz FSB), although it's currently registering in the BIOS as 750MHz given the motherboard is set to 100MHz FSB - and if I enable 133MHz FSB I should be able to unleash the delta.
Some homework suggests this mobo has a 'dip switch' box, a series of sliders that help alter the FSB. Trouble is, I have absolutely no idea what to set it to given my processor is not listed on the manual. NB: I'm very aware this CPU/mobo combination has been proven to work despite the manual suggesting it's upper CPU limit is 550MHz.
Any ideas? 😀
