First post, by derpmochump
need win98 driver for this please if anyone knows where I can get?
It's a serial port controller, here's a pic:
https://ibb.co/rkGvM4b
MSI MS-6734 KM3M mobo / Athlon XP 3000+ /512mb ddr1 ram
Voodoo 3 3000 PCI @185mhz / Aureal vortex 2 (dell oem)
3dfx ref. drivers win98se and dual boot with winXP-32 bit running amigasport 3.0 3dfx drivers oc'd with koolsmokey's V.Control in XP
Reply 2 of 6, by Horun
Try this driver. It says it is for Win 9x in the readme. Unzip and be sure to follow the instructions in ReadMe.txt. I scanned it at Virus Total:
https://www.virustotal.com/gui/file/bb0f62b96 … ed69e/detection
no virus found so it should be safe to try. Let me know if it works so it can be moved to VogonsDriver Library
    Logic3.zip
    576.57 KiB
    89 downloads
    Win9x driver for JT262/JT264/JT265/JT266/JT267/JT268
Reply 3 of 6, by derpmochump
derSammler wrote:
That's a standard gameport controller. You don't need any drivers. Just add it as a game controller via the control panel.
yeah thanks, but only 4-buttons out of 6 work with standard driver.
Reply 4 of 6, by derpmochump
thanks gonna try this soon!
Reply 5 of 6, by derSammler
In that case, give such infos right from the beginning, because your original post - talking about a "serial port controller" - made the impression that you had no clue about how to get this thing working at all.
