First post, by derpmochump
need win98 driver for this please if anyone knows where I can get?
It's a serial port controller, here's a pic:
https://ibb.co/rkGvM4b
P4SCE mobo/prescott p4 3ghz/4gb ddr1 in dual channel voodoo 3000 PCI @187mhz
3dfx ref. drivers / win98se with memory patch to boot with 4gb(1gb used)
dual boot with winXP-32 bit running amigasport 3.0 3dfx drivers
Reply 2 of 5, by Horun
Try this driver. It says it is for Win 9x in the readme. Unzip and be sure to follow the instructions in ReadMe.txt. I scanned it at Virus Total:
https://www.virustotal.com/gui/file/bb0f62b96 … ed69e/detection
no virus found so it should be safe to try. Let me know if it works so it can be moved to VogonsDriver Library
    Logic3.zip
    576.57 KiB
    7 downloads
    Win9x driver for JT262/JT264/JT265/JT266/JT267/JT268
Reply 3 of 5, by derpmochump
derSammler wrote:
That's a standard gameport controller. You don't need any drivers. Just add it as a game controller via the control panel.
yeah thanks, but only 4-buttons out of 6 work with standard driver.
Reply 4 of 5, by derpmochump
thanks gonna try this soon!
Reply 5 of 5, by derSammler
In that case, give such infos right from the beginning, because your original post - talking about a "serial port controller" - made the impression that you had no clue about how to get this thing working at all.
