First post, by feipoa
Does anyone know of any commonly available non-socket4 heatsink and clasp systems that will work for a socket 4 pentium 60? I'm assuming most Pentium 60/66's didn't have a glued on heatsink.
Reply 1 of 12, by Anonymous Coward
Most P60s used glue, because most of them came from OEMs. That's why it's hard to find them in good condition.
Reply 4 of 12, by dionb
I have one but I forget exactly what I used - I'll check this evening. Iirc I took one from an So5/7 system with a 'paperclip'-style clip and just bent it a bit to get it round the bigger socket.
Reply 7 of 12, by feipoa
Would you be willing to upload a photo of this? I've never seen a socket 4 with a 486-style heatsink clasp.
Reply 8 of 12, by Horun
I also have one with plastic frame and one with the "bent" wire, see pic. The the frame goes with gold colered HS, the wire goes with the black HS.
    258.42 KiB
Reply 9 of 12, by feipoa
Thank you. Very interesting. I've never seen one of those plastic clip mounts for a socket 4. The heatsink looks a bit small in area, does it cover the whole socket 4 pentium chip?
How much longer is the Z-clip for the Socket 4 than it is for Socket 5 heatsinks?
Reply 10 of 12, by Horun
Yes both HS cover nearly all the top of the cpu but do not hang over on any side, the wire is about 1/4" longer than a standard socket 5/7 metal clip.
added: the straight part of the wire is 2-1/2" long, the heat sinks are right about 2-1/16" square. My P60 is almost exactly 2-1/8" square.
Reply 11 of 12, by auron
i have bent the clasp downwards on a "manhattan socket7/370 cooler" and managed to fit it on socket 4. it even fits on socket 7 just fine after the bending. i'm not sure if there's any long term issues with using this on socket 4 due to possibly too high mounting pressure, but it seemed fine for quick testing.
a word of caution though, on the batman's revenge board there is a tiny smd capacitor right under one of the plastic tabs which can break off very easily while mounting/unmounting the cooler. it happened to me and i was able to solder it back on, but it was very annoying due to the position.
i also have some other "bent wire" style socket 5/7 cooler like in Horun's post, but was not able to make it fit on socket4.
Reply 12 of 12, by PARKE
Back in 1993 I bought a pc with a Diamond VLB board that came with this contraption. Still have it, It looks flimsy but is actually very effective:
100.1 KiB
