First post, by Auron359
I have an Asus P3B-F 440BX which i have been building my P3 system with, however when trying to test my Voodoo 5 5500 card nothing happens. I tried a brand new VGA cable still nothing and then i swapped it out for an Geforce 6200 which made the motherbaord make one long beep followed by 3 fast beeps.
I have finally figured out that if I unscrew the card from the bracket and "jiggle" the cards I will get lucky and everything works fine.
Kind of confused what is going on, part of me wonders if screwing in the bracket fully if pulling the opersite side of the card away from the AGP slot causing it to not work but even left alone its hit or mice.
Is this symptoms of a faulty AGP slot since it effects two different cards ?
