First post, by Cobra42898
Same PC I've been playing with, its a HP Pavilion 4550z, 466mhz Celeron.
The Bios sees the HDD, and gets the LBA sector number right, but only shows 65535MB .
Ive tried small primary partitions (10gb, 8gb), and the data is all garbage on it, via win98se fdisk/format.
if this were a win98 problem, it shouldn't occur only creating a 10gb partition. i copied win98 setup files to it, and scandisk finds crosslinks and a host of other issues.
is there a 64gb bios limitation?
Searching for Epson Actiontower 3000 486 PC.
