appiah4 wrote:AlessandroB wrote:
Pro Audio Spectrum. It was arguably the better sound card that lost the battle for PC audio standard against the Sound Blaster.
I sincerely hope someone does an Open Source, SnarkBarker-like clone of PAS one day so we all can build one. There is no such project at the moment, is there?
Snark Barker / SB1.0 uses off the shelf (still easly available) parts.
In case of PAS there are propertiary mediavision chips that will not be easly available. NuXT uses Faraday chipset (which was semi-popular in the XT times) and obtaining it is a bit problematic these days, so even if somebody will make PAS16 PCBs - obtaining parts for it will be a problem... Not to mention soldering all these SMD ICs, caps and resistors would be a big pain (Snark Barker is THT only, PAS16 relies on SMD) making it's audience very limited.
PS: Guy at 3dfx.pl currently works on clone Voodoo 4 4500 card, so I'm not saying it won't be possible, just saying it may be much easier to find original card than set of chips.
