First post, by appiah4
- l33t++
Many 430TX motherboards state support for 75MHz (and in some cases 83MHz) CPUs. Do these boards run the PCI Bus within spec while doing so, or does the PCI frequency also get an unintended proportional overclock?
Also, how does this work for non-Intel chipsets such as Aladdin IV+, VIA VPX etc.?
Asking because I'm trying to pick a board for a Cyrix mII..
EDIT: After some digging around in Google I came across this site: http://www.pchardwarelinks.com/chipsets_pentium.htm Painfully shows that there are nearly no Socket 7 Chipsets that have a 2/5 PCI divider. Actually, nothing aside from Aladdin IV seems to have a divider for Socket 7, and Aladdin V, 7 and VIA MVP3 and MVP4 are the only ones that have it for SS7.. Aladdin IV+ for me it is, then.
