First post, by athlon-power
- Member
The PSU in the full tower Dell 486 I just got recently is dead, which normally wouldn't be a problem, but it's one of those huge ones that are huge for no reason- the board inside them is the same size as any other AT/ATX PSU. Oh well.
I took it apart, cleaned it, got it back together, and the moment I hit the power switch, it shocked the f**k out of me through the power button lead, and started making a quiet(ish) screeching sound, so I am certainly not going to turn the thing on again, considering that it just tried to assassinate me.
Is there a way to get a standard PSU in that case without using the following tools:
- Grinder
- Drill
- Any dealing with making dodgy metal sheets for the other PSU
- etc.
I hate that it's dead, because the inside of it looks great. No swollen caps, no corrosion, the fuse is perfect, it all looks just fine. Why it tried to kill me through the power button of all things, and then started screeching, is a mystery for me. I didn't even get shocked while disassembling/reassembling it, no, just when I pushed the power button. Damn.
Where am I?
