First post, by Swiego
Any suggestions on a good Slot 1 CPU cooler for my old P2? I don't mind used but ideally it would be something for which I could replace the fan with a newer model if it's gummed up at this point. I've been shocked how hot the P2/450 I picked up gets.... currently just using the cartridge + a Slot 1 heat sink (clearly designed for a lower clocked CPU). Under even light load it gets far too hot to touch... I'm currently leaning a 120mm case fan on the heat sink.
