486ODPR66 (P4T) and PODP66 (P24T) are totally different beasts, the one basically a regular DX2-66 with a heatsink and different name, the other a Pentium with onboard voltage regulator and only 32b of the 64b bus connected. Also the ODPR66 has WT cache and the PODP66 has WB cache. So a whole host of jumpers need to be set differently. *Don't* use the P24T settings.
As for what you should use, see your own link:
There is not much difference between an DX2ODPR66 and a standard 486DX2-66
So just use the regular i486DX2-66 settings as with option P, as Horun already stated.
Must say that this is one fancy board - possibly one of the highest-specced 486 boards out there, with some of the simplest, most intuitive jumper settings too - that really deserves a Cx5x86 and EDO, not an ODPR that could run in some old 1993-era thing just as well.
