Reply 20 of 23, by gdjacobs
- l33t++
truemaster wrote on 2020-01-16, 07:29:nichicon pw is low esr for the 1000mf a 820mf is good they will need a very little bent to oposide in cpu area. the 11.5 heigh of the fujicons leave 2mm space before hit the back plate of the slot cpu. are you sure the 100mf caps need replacement with low esr also? they are licon LRM found as RM at fujicon and the datasheet show them as normal
I wasn't finding anything in Nichi and Panny's higher ESR ranges with a compatible case size. Are they distributed fairly widely around the board? If so, they're probably used for noise decoupling in which case I wouldn't worry about ESR being a little lower.
