Reply 20 of 21, by Sedrosken
- Member
The_ED wrote on 2020-01-15, 17:55:It's Noctua NF-A6x25 FLX model, it comes with L.N.A. and U.L.N.A. adapters, that makes it spin slower. Probably resistor modded adapters from factory. 😀
Here in Latvia that Gelid fan is priced similar to Noctua, 3-4€ difference, but availability is poor.
Can confirm that the low noise adapters just put a resistor on the 12v line. Bear in mind that even at 3000RPM these Noctua fans are almost alarmingly quiet -- I had to keep checking for about the first day I had it that it was still spinning.
