First post, by SirNickity
I've seen a few strange problems here lately that I've run across myself and happened to know the answer, so I thought I would throw this one out there and see if anyone else has wrestled with this particular demon...
I just put together a new Cyrix 6x86 build using a Zida TX100 motherboard. Most of the hardware is new to me, so I haven't established any known-goods yet. I connected a Seagate 10GB HDD to the primary IDE, booted from a W95 OSR2 boot floppy, and ran fdisk to create a 3.5GB partition. Rebooted, then "format c:", which runs for a while.. maybe 11%, maybe 25%, then fails "NOT READY" and back to the A: prompt. If I re-run it, it just dies at some new random point.
Tried:
- Swapping drives (it's not the drive)
- fdisk /mbr, repartition (no overlay, no translation issues that I can see)
- FAT16 (2GB part) and FAT32 - no change
- Swapping for 80-conductor cable
- Turning off DMA
- Changing PR200+ clock from 75x2=150 to 66x2=133 (just in case the IDE controller doesn't care to run at 75MHz)
Suspicions:
- It's a VIA chipset, and I've never gotten the hang of those
- BIOS seems to be fine with >8GB drives, but...?
- Using 128MB PC133 RAM stick, which the board only detects as 64MB (supports 2x256MB though), but memtest+ gives thumbs-up
I'll give the secondary IDE channel a try, although I'm not sure how I feel about leaving it that way if it works...?
