First post, by keenmaster486
- l33t
I have a couple of printers in the house, both of which are connected to the home network one way or another.
It is easy enough to print to them from any network-connected PC running anything even as old as Windows 3.1 (yes, it can be done).
But what about DOS-only machines that can only print to a parallel or serial port?
Can I somehow hook up the serial port to the USB port on my modern printer and print that way?
I'd probably just be sending raw text to it, as I don't think any DOS-only machines I'd be doing much fancy word processing on. But you never know, there could be some Postscript involved.
What I really want is something that I can plug into the parallel port that will make my modern network printer appear as though it were physically and natively connected to the port. Ideally the DOS machine has no idea it's actually printing to a network printer.
Yes, I have found LPT2USB. It is sold via some weird form system -- seems kinda shady and I don't want to use that.
Perhaps figuring something out with the serial port is my best bet?
World's foremost 486 enjoyer.
