First post, by Jed118
I created a video comparing various media and running them through a speed test on the same machine. First vid on new machine with Premiere installed. WAY better than OpenShot, a bit of a learning curve but NO CRASHES! 😁
Spreadsheet outlining performance findings https://files.fm/u/3dtg978w I'll probably have to re-host that somewhere.
Here's the result:
https://youtu.be/-qIS-gC_j7Q
Enjoy!
What's for sale? my eBay!
Reply 2 of 11, by Jed118
dionb wrote on 2020-01-20, 09:13:
Nice! RLL and ESDI would be cool too - but even harder to find, so no surprise you weren't able to include them.
I have an RLL drive, but no controller. Also, the last time I saw it was in the early 2000s, buried somewhere in my closet . I seem to recall that when I last spun it up, some less-than-pleasing sounds came out of it.
ESDI, now there's something I haven't seen in a very long time.
Reply 3 of 11, by Horun
Your Title is misleading and the xls cannot be opened by standard apps. Comparing late model SD adapters to real HD's is not what I was expecting from your title. If this was usenet you would get a "plonk" 😁
Reply 4 of 11, by dionb
Jed118 wrote on 2020-01-21, 04:14:
I have a massive full-height 540MB ESDI drive from the days when 120MB was a big HDD. Have been looking out for a suitable controller for over a year now. Not too seriously though (as in: willing to part with significant money for it) as I'm not realistically be using something like this regularly. I do however have an almost identical 600MB SCSI drive which would make a good comparison. That drive is cosmetically inside my XT clone case - but as it can realistically simulate a jet engine starting and a minor earthquake when seeking, I don't normally have it powered up 😉
Of course I did have an RLL controller a while back - but gave it away as I didn't have any suitable drives...
Reply 5 of 11, by Jed118
Horun wrote on 2020-01-21, 05:25:
Oh? How would you title it? What would you differently/change? My goal was to test the various different drives available, plus modern alternatives. How would you have compared them (maybe I'll do a part II or a revision!)
Yes the XLSX was made in LibreOffice on an old laptop as I was doing the tests. It opened up on Excel O365 Pro Plus just fine though...
Reply 6 of 11, by Jed118
dionb wrote on 2020-01-21, 08:38:
*edit - damn ISA ESDI controllers are indeed not cheap!
I had a Seagate Barracuda 2 gig that was in my 386/486 DLC eternal project that I used for many, many years. Alas, a lot of quick power ups and power downs killed it a few years ago. It still spins up, but there's no longer a connection between the SCSI controller and the data portion (the controller will see the drive, but not the media) 🙁
It was (and still is, it's hooked into that rotating hard disk stand I have) quite loud - that sound reminds me of the golden years of PC computing 😉
Reply 7 of 11, by Horun
Jed118 wrote on 2020-01-22, 01:06:
How about: MFM, IDE, EIDE, SCSI, SCSI2 and SD using various adapters ? That would be more accurate.
Added: Also if you want others to contribute using their controllers and drives perhaps naming the HD util used for each test would be a good idea, just a thought...
Reply 9 of 11, by Jed118
Horun wrote on 2020-01-22, 01:37:
I suppose I could rename the video title, but not in the video.
Adding the names of the utilities is a good idea as well. I will add it in the description.
Reply 10 of 11, by The Serpent Rider
Interesting. I'm surprised SCSI was the winner.
That's mostly because 430VX chipset was used.
Reply 11 of 11, by Jed118
The Serpent Rider wrote on 2020-02-06, 07:59:
I used what was available around here that would accommodate such a spectrum of drives. Having said that, the read speeds as reported by PC Config seem to plateau.
Man, I need to find a new place to host that XLS...
