Socket 3 vs Socket 4 build
First post, by Tobi19
Hi guys,
I was planning to make some PC builds going from Socket 3 486DX4-100MHz to Socket 370 Pentium III Tualatin 1400Mhz. My idea was basically getting the best hardware for each socket (somewhat period accurate) but there is something troubling me. Will a Socket 4 build with a 66MHz Pentium be an upgrade over a 100MHz 486DX4? I know Pentiums are more clock efficient than 486s and already read the 486 comparison PDF. If the 486 performed a 58.9% of a Pentium 100 MHz, does it mean it performs like a Pentium 58.9MHz (or 60 MHz since it's the closest one)? I would like to know if it's worth it having a Socket 3 and a Socket 4 build or if it's better to just skip Socket 4 and go 3, 5 and 7.
Reply 1 of 41, by The Serpent Rider
If you want practical build for DOS and early Win9x, find 430TX board and use Pentium MMX. This setup is very tweakable for gaming.
Reply 2 of 41, by mpe
Except for apps that use FPU (Quake), the DX4-100 delivers performance is roughly comparable to the P66 if not slightly better in many non-pentium optimised apps. At least when using DX4 on a fairly modern 486 motherboard and not on some old junk.
There are also faster CPU options for both platforms AMD 5x86, Cx 586, Pentium overdrive 63/83 for Socket 2/3 and somewhat rare Pentium Overdrive 120/133 for the Socket 4 if you want best what's available which close the gap or even eat well into entry S5/S7 performance levels.
Blog|NexGen 586|S4
Reply 3 of 41, by derSammler
A DX4-120 will beat a P66 in integer maths, but not in floating point maths. But the DX4 is not even the fastest Socket 3 CPU. The fastest Socket 3 CPU you can buy is the Cyrix 5x86 @ 120 MHz. Having that and a P66 doesn't make much sense - at least to me - because the Cyrix 5x86 is much faster. Not to mention that Socket 3 can also take a Pentium Overdrive with 83 MHz. But I would rather skip Socket 3 than Socket 4. If you go for Socket 1 instead of 3, you are limited to 5V CPUs, which means fastest is Cyrix DX2-80 or Intel DX2-66 (5V version, it exists as 3.3V version, too) and this will give you the most commonly used 486 configuration of the chip's heyday.
If you do both Socket 5 and 7, you'll face a similar problem, since all Socket 5 CPUs are working in Socket 7 as well - and the difference between Socket 5 and Socket 7 is much smaller than between So7 single-voltage and So7 dual-voltage anyway. Better skip So7 in favor of Super Socket 7.
Reply 4 of 41, by auron
it's worth knowing that playing with the test registers on pentiums gives you extra slowdown options, see here. for example i recall reading that the 2nd pipeline can only be used 10% of the time on code not compiled for pentiums, and the results there (VPD switch) seem to roughly confirm that.
it seems the practical way would be to build a socket 7 pentium/pentium mmx machine for DOS, and a fast coppermine or tualatin for win9x. the k6+ chips are liked for their open multipliers but they (and the motherboards for them) are quite expensive nowadays. socket 4 can be skipped unless you want it for the novelty factor. there were also plenty of cacheless intel socket 5 p75 boards that should perform right about like a p60/p66, or even slower, as cacheless socket 4 doesn't appear to have been a thing.
Reply 5 of 41, by derSammler
auron wrote on 2020-01-22, 16:04:
That's completely irrelevant, as he stated his goal:
Reply 6 of 41, by Doornkaat
Hey and welcome! :-)
Tobi19 wrote on 2020-01-22, 14:53:
A Socket 4 system is a cool thing to have but it does not fill a performance gap between what's offered on the Socket 3 and Socket 5 platform.
That being said for gaming I wouldn't bother with specifically looking for a Socket 5 board either. My advice would be to look for a decent late Socket 7 motherboard for both Pentium and Pentium MMX or skip P5 altogether and get a K6-2 and slow it down as needed via SetMul.
Have fun! :-)
Reply 7 of 41, by Doornkaat
derSammler wrote on 2020-01-22, 17:17:
Since I made a similar suggestion as auron I want to point out Tobi19 also asked
so I guess it is indeed relevant info.
Reply 8 of 41, by auron
as Doornkaat remarked, it's not a set goal judging by the OP and really if it were there would be not much point in asking about it, as he could just look up the fastest CPU/max RAM support for each platform and go for it, no?
just out of curiosity, why do your posts frequently have this condescending tone to them?
Reply 9 of 41, by BinaryDemon
Technically the best performing Socket 4 cpus would be the Pentium Overdrives at 120mhz or 133mhz but really you should be considering socket 5 at that point.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 10 of 41, by The Serpent Rider
Bottom line:
PCI Socket 3 with Am5x86 160Mhz will provide better experience for the most games they both can run adequately. Or at the very least it will be on par with Socket 4 P66 in some scenarios (Quake).
Reply 11 of 41, by dionb
The Serpent Rider wrote on 2020-01-22, 19:06:
Bottom line:
Assuming your Am5x86 actually runs at 160MHz. I have four, all do 150MHz (3x50) without complaint but either don't boot at all or aren't stable at 160MHz (4x40). YMMV. Same applies to bus speed - some boards and CPUs (like the very late UMC-based PCI board I ran those 5x86 on) are happy to do 50MHz, many 40MHz, but for trouble-free operation on pretty much any hardware 4x33=133MHz is a safer bet. And still faster than a P66 in anything other than FPU (=Quake).
Reply 12 of 41, by The Serpent Rider
With 4V?
Reply 13 of 41, by dionb
The Serpent Rider wrote on 2020-01-22, 19:33:
With 4V?
Nope, that makes the difference between not booting at all and booting but hanging somewhere after POST at 160MHz, but doesn't make it stable. Looks like I've just been unlucky in the lottery. It's also not bus speed related as 3x50MHz is solid.
Reply 15 of 41, by mpe
dionb wrote on 2020-01-22, 20:31:
Just get another one. Late date -ADZ or -BGC. Many of them work well at 160. At least all mine do (I have three 5x86's). No extra voltage and standard cooling.
However, the 150/50 is preferable over 166/40 as it is better in most apps as soon as your board can handle 50 MHz with no extra ws.
Blog|NexGen 586|S4
Reply 16 of 41, by AlessandroB
Like me, if you want a P60/66, is just "to have it", to experiment with such rare and historically milestone. It is the only x86 system in which there is practically only one CPU, 60/66 is a very small difference. This makes it, together with other features, a very mysterious collector's piece.
Reply 17 of 41, by The Serpent Rider
HIstorical value, hardware collecting, period specific benchmarking? Sure. Practical use for games? Eh, not really. Unless you can find Socket 4 CPU and motherboard extremely cheap and don't have PCI Socket 3 already.
Reply 18 of 41, by AlessandroB
The Serpent Rider wrote on 2020-01-22, 21:51:
If you point to retrogaming to a specific restricted area of 486 era games without asking him for 3D games that require fast Pentium and 3D card... it might be a fascinating option.
Reply 19 of 41, by dionb
mpe wrote on 2020-01-22, 20:54:
Three are -ADZ...
Yes, and that gives me a little dilemma - I originally wanted to make my 'ultimate' So3 build with Cx5x86-100@120 and 40MHz VLB. But that board does 50MHz FSB which makes it almost a shame not to use the Am5x86 with 3x50MHz on it. My PCI late So3 board also can handle 50MHz, but that drops PCI to 25MHz, which nerfs performance too much. Maybe I should put the Cx5x86 on there. But then I have *yet another* system with no room and no valid software reason.
Oh, and I also have a nice So4+P60 board sitting around looking pretty...
/FWP 😉
