First post, by lgj1107
I got my hands on an AMD 286 computer, but I can't find out what motherboard it has, and therefor not sure about jumper settings etc.
    1.75 MiB
    1.57 MiB
Reply 2 of 18, by Anonymous Coward
The CPU in this board is unusual since it doesn't appear to have a speed marking.
Reply 4 of 18, by Cyrix200+
The crystal would suggest a 12MHz part, but still odd it isn't marked. QT-129 seems to be a type indicator, but Google doesn't recognise it. The QA sticker might be a brand? LIN? UIN?
Where did you get the board? Any markings on the back?
1982 to 2001
Reply 7 of 18, by lgj1107
There is no mark on the back. The board was bought in the second-hand market. BIOS dump is incomplete.
    QT129-HI.zip
    11.85 KiB
    58 downloads
Reply 8 of 18, by Cyrix200+
Hm, that's a nice puzzle 😀 With half the bytes missing, it's hard to tell what it is. In this thread: 80286 Mainboard Bios needed there is a reference to this BIOS file: http://chukaev.ru54.com/bios_cs_en.htm#Texas_Instruments.
It's an AMI BIOS for the same chipset. It might work.
Won't give you the answer to the jumper / DIP switch settings yet, but might help...
1982 to 2001
Reply 10 of 18, by maxtherabbit
Anonymous Coward wrote on 2020-01-28, 09:00:
it used to - if you look close you can see the remnants of a -8
Reply 11 of 18, by Cyrix200+
maxtherabbit wrote on 2020-01-28, 15:12:
With a 24MHz crystal, would that be divided by 3 then?
I think it's the remnants of 12-S.
18.03 KiB
1982 to 2001
Reply 12 of 18, by maxtherabbit
Cyrix200+ wrote on 2020-01-28, 15:21:
With a 24MHz crystal, would that be divided by 3 then? […]
yeah good call
Reply 13 of 18, by Anonymous Coward
Being a Chinese motherboard, perhaps the CPU was being overclocked and the speed rating was sanded off to obscure that fact.
Something else odd I noticed about the board is the memory configuration. It has four SIPP sockets and four rows for DIP memory (which is pretty normal), but what is up with the extra sockets in the top right corner (which unlike there other DIPS memory banks don't seem to support parity)?
Reply 14 of 18, by maxtherabbit
Anonymous Coward wrote on 2020-01-28, 16:49:
I think you nailed it I bet it said - 10/S before
Reply 15 of 18, by Predator99
Thats easy. Inside your dump I see
"AadSfwrB OPTBE26BO OYIH wr otaeIcSfwr n.AadSfé W26MdlrBO eso .3LCprgtAadSfwr n. "
Translated:
A a d S f w r B O P T B E 2 6 B O O Y I H w r o t a e I c S f w r n . A a d S f
Award Software 286 BIOS COPYRIGHT Award Software Inc.Software Inc. Award Soft
2 6 M d l r B O e s o . 3 L C p r g t A a d S f w r n .
286 Modular BIOS Version 3.03HL Copyright Award Software Inc.
Your BIOS is Award 3.03HL. You will find it easily.
Reply 16 of 18, by quicknick
Here's a couple of AMI BIOSes for the TACT823xx chipset. Hope you can get your board working, mine is still dead (but haven't given up yet).
Unknown TACT 286.rar
90.62 KiB
43 downloads
(Original high/low = what was on my board. Other two, from chukaev.ru54.com - they seem to be a newer version)
