First post, by muon
Recently I got this motherboard. I've seen that there is a BIOS version without BUG of year 2000 and with Amd P75 CPU support, but in the upgrade process the BIOS that I should choose it depends the IO Core Logic of the mainboard: NS 332 or NS 311 / 312
     Please find attached file of BETA BIOS for 486 PIO2 which will support Year
2000.
xxxxx101 --> for EPROM (Program the BIOS using an Eprom Programmer)
xxxxx701 --> For EEPROM (Program the BIOS using a Flash Utility ->
AFLASH3)
xxxxCxxx --> NS 332 IO Core Logic
xxxxBxxx --> NS 311 / 312 IO Core Logic.
Please refer to Year 2000 and LS-120 table.
What hell is that? How I can know the NS IO logic of the mainboard?
Thanks in advanced
Reply 1 of 6, by fitzpatr
This is referring to the sticker on your motherboard's BIOS chip.
At the image in the link, at the bottom right of the image (upside-down) to the right of the CMOS battery, the sticker has an 7-digit code (103C701 in the picture).
http://www.amoretro.de/wp-content/uploads/fic … motherboard.jpg
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 2 of 6, by muon
fitzpatr wrote on 2020-02-09, 21:45:
OK. Thank you very much.
My motherboard is B
Reply 3 of 6, by dionb
That's the (E)EPROM version. The I/O chip is the medium-sized rectangular chip to the left of the second PCI slot on that pic.
Reply 4 of 6, by muon
dionb wrote on 2020-02-10, 10:07:
This is a picture the my mainboard:
I understand it is B. Is it ok?
Reply 5 of 6, by muon
Another question. I've seen there is two revision of the motherboard, but I haven't seen any visual differences. How I can know what revision is my motherboard?
https://stason.org/TULARC/pc/motherboards/F/F … -PIO-2-REV.html
https://stason.org/TULARC/pc/motherboards/F/F … -486-PIO-2.html
Reply 6 of 6, by dionb
muon wrote on 2020-02-10, 13:38:
This is a picture the my mainboard: […]
Yes, that's the 311 all right.
