First post, by buckeye
I know big decision here, but my retro setup is on a fold up table with a surface that makes the mouse
"twitchy". A trip to Walmart showed various brands steelseries, corair, etc. for least 12 bucks. Any
recommendations here that might be cheaper?
Foxconn Q45M E8400 Core2 Duo 3GB DDR2 800 BFG Geforce 7950GT 512MB X-Fi Xtreme Music 500W XP SP3
Intel SE440BX P3 450 256MB 40GB Voodoo 3000 16MB SB 32pnp 350W 98SE
Intel DH61CR i3 LGA-1155 8GB DDR3 EVGA 1050ti 4GB 480GB SSD 650W
Reply 3 of 11, by Mister Xiado
I've only ever had tracking issues with pads that had grids printed on them.
I always use your typical cheap foam mouspads you can get from places like ArtsCow. I had a few with my insignia made about ten years ago, and they're still working fine with every type of mouse I use, though they periodically need some scrubbing.
b_ldnt2.gif - Where it's always 1992 (or so).
Reply 4 of 11, by Unknown_K
Cooler Master mpa-mp720.
https://www.wootware.co.za/media/catalog/prod … 993-094_001.jpg
Large for people who like a lot of mouse movement, easy to clean, very precise surface, very rigid, you don't have to use the lighting.
Reply 5 of 11, by buckeye
Thanks all for the ideas. I'm using paper right now, never thought to use cardboard.
Reply 6 of 11, by Errius
An old hardback book works.
What's the problem here? The mouse can't handle surfaces that are too smooth?
Windows XP End of Support is on April 8th, 2014. Click Here to learn more.
Reply 7 of 11, by pentiumspeed
What I mean is patterned, and texture either works well with one condition: matte surface. Since shiny surface even has patterns in it since LED reflects too much and blind the sensor.
Cheers,
Reply 9 of 11, by buckeye
Errius wrote on 2020-02-14, 21:46:
This is just one of those cheap fold-up tables, guess the texture on it is throwing it off.
Found a cheap plastic mouse pad at work that's doing the job.
