First post, by PTherapist
I've been working on my 486 and am constantly running into an error trying to boot Windows 95. I thought I had it sorted, but turning it back on this morning yielded the same result. I've tried googling the issue, but not really getting anywhere so thought I'd try posting here.
Basically the system is setup like this:
XTIDE Universal BIOS installed on an EEPROM on a 3Com Ethernet card (version 2.0.0 beta 3, tried both WITH & WITHOUT the Win95 patches)
Only 1 IDE channel with:
IDE Master = 1GB CF Card
IDE Slave = 120GB HDD
CF card is formatted as a single partition FAT32. The HDD partitions are irrelevant to this issue, as the problem occurs even with the 120GB HDD disconnected.
After doing a clean install of Windows 95 C (also tried with B and had the same issue) it will work fine for some time. Then I'll switch off the PC and come back to it later to be greeted with the following error upon boot:
While initializing device IFSMGR: The Microsoft Installable File System Manager found an incompatible version of the helper driv […]
of the helper driver. Please ensure that the correct version of
IFSHLP.SYS has been installed.Press any key to continue...
And then it shuts down.
If I'm lucky after a few dozen ALT, CTRL, DEL & switch off/on routines it will sometimes decide to boot up fine. But the problem will reoccur at random intervals.
Anybody experienced this with Windows 95 before? I'm suspecting XTIDE to blame so am going to experiment with different versions of the XTIDE BIOS. But just wondering if anybody has any other ideas?
