First post, by Planet-Dune
So I bought an Abit BX6 and an Abit LX6. After arriving home and putting them on my test benches, both do exactly the same, nothing at all. I tried with a CPU, without, with RAM and without, gpu, all loaded, nothing etc... nothing on the screen, no beeps, no nothing. I am using a standard power supply. (tested a few)
I'll include a picture of the boards.
These boards are pretty old naturally but really well cared after. The fact BOTH do exactly the same nothingness makes me suspect I am at fault and not the boards, somehow. I have little experience with motherboards of this era and maybe I am just doing something wrong?
Reply 1 of 16, by Doornkaat
Have you asked your other account, FrankDM yet like you did in that other thread?
Valuation of old hardware
Maybe he can give you an answer.😉
Reply 2 of 16, by oohms
I have consistent problem with ram, and a lot of boards are (or have become) very fussy about how the sticks are seated. With some boards, if i don't symetrically click in the sticks on both sides at the same time, it won't boot
DOS/w3.11/w98 | K6-III+ 400ATZ @ 550 | FIC PA2013 | 128mb SDram | Voodoo 3 3000 | Avancelogic ALS100 | Roland SC-55ST
DOS/w98/XP | Core 2 Duo E4600 | Asus P5PE-VM | 512mb DDR400 | Ti4800SE | ForteMedia FM801
Reply 3 of 16, by Errius
What are those workbenches?
Is this too much voodoo?
Reply 4 of 16, by Planet-Dune
Doornkaat wrote on 2020-02-20, 11:46:
Yawn 😉 We can make it a meme with you posting a reply with every post I make 😀
Reply 5 of 16, by Planet-Dune
oohms wrote on 2020-02-20, 11:58:
I tried with no ram at all as well, it should at least give me either something on screen or if not, a beep right?
Reply 8 of 16, by Munx
1. This might sound silly, are you sure the CPU is in all the way? I had some scares over the years where slot processors needed an extra push to be inserted properly.
2. Did you try other ram sticks or video cards? Certain boards just dont like certain ram configurations and video cards. Example - my Aopen 440bx board refuses to post with some ram sticks that work great in other boards.
My builds!
The Underdog - The budget K6
Reply 9 of 16, by amadeus777999
Connect a speaker & use a diagnose card.
Reply 10 of 16, by appiah4
amadeus777999 wrote on 2020-02-20, 14:03:
Listen to this man. He speaks the true true.
Reply 11 of 16, by Baoran
Planet-Dune wrote on 2020-02-20, 12:11:
You can try to make it a joke as much as you want. It just proved that you can't be trusted and I would be much less inclined to answer your questions.
Reply 13 of 16, by imi
don't bother, they cost more than an actual good quality case.
Reply 14 of 16, by pentiumspeed
Yea. Speaker and diagnostic POST code card. And some quality memory modules, don't reuse what you have now. I do not trust these.
I always keep spare memory modules. All OEM brands on their offical stickers attached to memory modules: Hynix, Samsung, Micron or Crucial, Elpida but only two exceptions: I had very good experience with Mushkin and Kingston the two good third party memory makers who buy chips and assembles theirs own from open market.
Cheers,
Great Northern aka Canada.
Reply 15 of 16, by oohms
Planet-Dune wrote on 2020-02-20, 12:12:
you won't get anything on the screen, but you will get beeps if it is the memory. A POST diagnostic card can also be of some help
Reply 16 of 16, by appiah4
No RAM or RAM in wrong bank will give you nothing but memory error beeps.
