First post, by rob8086
As the title implies, I'm trying to find what the very last type of PCMCIA wireless card was.
I can comfortably say there are no PCMCIA 802.11ac cards in existence. But! I did find a Cisco card supporting draft 802.11n, found here. So I guess what I'm trying to figure out is if there are any newer cards available than this one.
Thoughts?
Edit: I believe this dual-band 802.1n card is significantly newer than the one referenced above. The search continues.
Corruptor : ASUS TUV4X - Intel SL6BY @ 1.4GHz - 2x 256MB PC133 - ATI Radeon 8500 - Creative Sound Blaster Audigy2 ZS SB0350
Aggressor : ASUS TUSL2 - Intel SL6BY @ 1.4GHz - 2x 256MB PC133 - NVIDIA GeForce 4 Ti 4600 - Creative Sound Blaster Audigy2 ZS SB0350
Reply 2 of 3, by Horun
What gdjacobs said ! Curious what are you installing it in ?
Why I ask is the older 16bit PCMCIA is limited to 20Mbytes, the newer (using PCMCIA connectors) are Cardbus 32bit bus 132Mbytes. If your older Laptop is using 16bit interface then going to a faster card will not help you much, specially if it does not support Cardbus. Just a thought...
Reply 3 of 3, by rob8086
gdjacobs wrote on 2020-02-22, 02:34:
You need to differentiate between PCMCIA, PCCard, and ExpressCard.
Right you are! I've always used PCMCIA as kind of a catch-all and that's wrong. For my specific purposes, I'm looking for PC Cards for an Inspiron 8100.
