First post, by HanJammer
As most VFX1 owners knows the HMD suffers from the same problem as headliners in old 80s and 90s cars - foam padding deteriorates and disintegrates into black annoying dust, cloth falls off from the foam. Everything smells like old wet carpet. Do any of you guys found a way to fix it? I was thinking about buying a piece of car headliner cutting it into dimension and gluing it back into place - what do you think? I may even bring it to specialized workshop (I'm into vintage cars so I know some of them) so they will do it for me, but maybe there is a better way?
Reply 1 of 3, by xjas
At least on mine, the foam was just held on by sticky velcro pads, so you can rip it out and try different things until you find something you like. I just used the old pad to make a pattern and cut some ~1.5cm thick dark grey padding foam to fit. It sticks to the velcro and does the job.
Reply 2 of 3, by bushmac
For the ear pads, I bought the following: https://www.brainwavzaudio.com/products/headp … ds-xl-sheepskin
Any round ear pads with those measurements will do. Things to note:
- The ear pads are clip attached to the headset's audio drivers. You should be able to rotate the ear pads counter-clockwise (when facing the inside of the headphone pads/driver) to remove the pads.
- The original ear pads are glued to some plastic discs. I had to cut and tear off the fabric to remove the old pads
- Even after cutting some holes to expose the old clip holes for the plastic mounting discs, sliding the pads back into the drivers was a tight fit. I got there, but it took some effort
- The headphones are a tighter, but plush fit after everything is said and done
Hope this helps.
Win 98 Box
Windows 98SE
Voodoo 3 3000 AGP
ATI All-In-Wonder Rage II + DVD PCI
512 MB SDRAM
PIII E 700 MHz
Dell SE440BX-3
Win XP Box
Windows XP Home SP 3
Radeon 9800 Pro 256 MB
2 GB DDR
P4 HT 3.2 GHz
Gateway D865GLC
Reply 3 of 3, by HanJammer
bushmac wrote on 2024-02-18, 17:34:
For the ear pads, I bought the following: https://www.brainwavzaudio.com/products/headp … ds-xl-sheepskin […]
Hope this helps.
Well, my question was about the foam around the head... Earpads are not such a problem. You can still buy replacement earpads which will fit without any modifications (ie. https://allegro.pl/oferta/nauszniki-akg-k300- … kosc-9409994825 ). VFX-1 uses AKG headphones - pretty popular K-301 (and similar) models use the same parts. In fact I bought a set of AKG headphones to service one of my VFX-1 HMDs (which is missing one of the transducers).
Anyway, these headphones are so nice I now have a dilemma if I should part them out to service VFX-1 or leave them be (just replacing the earpads on them ;D )
