First post, by AngieAndretti
I have an opportunity to purchase an external backpack 5.25" floppy drive that connects to a PC via parallel port. I've never used an external floppy drive on a retro PC before, but I read that a driver is required so this must be handled differently than internal floppy drives. I'd love to hear from anyone who has experience with one of these devices! Any information/memories appreciated!
UPDATE: I found what I believe to be the correct driver and manual, and it appears the drive CAN tolerate both A: and B: being taken, which is really cool! Manual says it'll assign to the next available drive letter. Also says it's compatible with DOS and Windows 95, so I'm sure operation in Win98SE should be fine too. I'm excited! I want to re-experience the look and feel and the sounds of the old floppy setup. I want to open a shrink wrapped box of NOS floppy discs and just give 'em a good sniff! Lol, I don't remember if they actually had a smell but it's generally important to smell your new retro stuff 😀
Reply 3 of 8, by Dhigan
Hello !
I have the ROTEC RF542BT à 360ko floppy drive parallel port.
Still looking for the driver ...
Anyone please ?
Win 3.1 : HP Omnibook 425 + Toshiba T2130CT
Win 9x : Dell Latitude Cpx H500GT + Dell GX1
Win XP64 : Asus P5B Xeon
Reply 4 of 8, by Horun
Dhigan wrote on 2020-03-08, 20:46:
Hello ! […]
Hello !
Anyone please ?
Have you tried the BackPack Floppy driver ?
http://minuszerodegrees.net/5160/floppy_diske … te/option_4.htm
http://minuszerodegrees.net/transfer/35_inch/ … _dos_driver.htm
or
https://winworldpc.com/product/backpack-drivers/2002
Reply 5 of 8, by Dhigan
Horun wrote on 2020-03-08, 21:14:
Thanks ! I will have a try at them and let you know.
Reply 6 of 8, by Tetrium
I've experimented with the Backpack external 3.5in floppy drives. These were also parallel and were basically external cases with an internal pc floppy drive inside of it with an adapter.
These had only drivers for windows 9x though, iirc, but these external floppy drives were able to have the internal 1.44MB floppy drive switched with a standard pc 2.88MB floppy drive and it worked! 😁
It was very slow though but at least it worked 😜
I can't remember having ever tried the 5.25in Backpack as I never found any or didn't want them badly enough (costly).
My retro rigs (old topic)
Report spammers here!
Reply 7 of 8, by Dhigan
Well ... I tried but no luck 🙁 Did DOS and win98SE versions.
I can see the green light of the floppy drive, but can't figure out if the drive is dead or if I don't have the good driver.
Any ideas ?
Reply 8 of 8, by liqmat
Try the driver CD. This covers all their drives. Just hunt through it for your driver. I own the 3½" model and it works in DOS, Windows 3.1, 9x, etc. so give it a try. Good luck!
http://minuszerodegrees.net/backpack/backpack_setup_cd.htm
