First post, by foil_fresh
I've got a Lucky Star Slot 1 440BX motherboard and have bought a P2 266 Klamath to do some underclocking for DOS games - this board has it's multi and fsb clock settings in BIOS not switches/jumpers, making it ideal for this unlocked P2.
Browsing through the manual I saw something that stood out - TURBO66
"TURBO66 is an over-clocking jumper which enables 66 MHz CPU to run at 100 MHz. TURBO66 is only reserved for internal test only. No guarantee is provided for over-clock setup."
Should it be connected to a switch or momentary connection? Sadly the only AT case I have is baby-AT and won't take this sized board. Any reccomendations for 3.5" or 5.25" bays that have a turbo switch?
ideally if this thing can be switched while the pc is on, then i can quickly go between 250mhz (100 x 2.5)and 166mhz (66 x 2.5) without rebooting - perfect for any dos game that gets divide errors when running on CPUs at over 200mhz.
http://www.elhvb.com/mboards/luckystar/manual … BX2V/6abx2v.pdf
any other boards with this jumper? thoughts? does anyone have experience with this kind of jumper?
cheers
