Hi guys, thanks all for the reply on this topic
i was able to finally buy replacement capacitors for this motherboard, and because of the pandemic i managed to have time and exchange 5 caps, which are the ones that are near the mosfets.
The result was still ..BAD
on the image i posted, the mosfet on the top gets to 60-65 degrees celcius, the mosfet at the bottom gets to 80-or 90 degrees celcius.
the board works, i left it running for 20minutes playing doom. But the amount of heat that it ends up with is tremendous.
After turning off the power supply , i touched the back part of the motherboard where the mosfet is , and its relly hot.
mosfets have these markings (picture attached) Im open for suggestions, should i find replacement mosfets? do you know what current mosfets on the market can i use for replacement?
or maybe i should buy some expoxy thermal compound and attach a heatsink on the black part of the mosfet?
Im asking this because the motherboard is very strange to find and i want to keep it good as much as i can.
processor installed is a amd k6-3 / 400 , 2.4v core
jumpers are
voltage jumpers set at 2.4v
nbclk1 2 and 3
sdram 2 and 3
nbclk2 1 and 2
sram 1 and 2
freq1 2and3
freq2 1 and 2
freq3 2 and 3
clk1 1and2
clk2 1and2
clk3 2and3
clk4 1and2
