First post, by NautilusComputer
So this is possibly available sort of near me and it's the only photo I have. Could you folks lend me some wisdom on ID'ing it, and whether or not it's worth picking up?
I cant help ID the board but do spot the start of corrosion above the battery. So wether or not you are comfortable removing and cleaning that should be a factor on wether or not its worth you getting it 😀
This one?
https://stason.org/TULARC/pc/motherboards/A/A … 6-MST-410S.html
I don't think it's a very desirable motherboard given that it has only ISA slots.
That does seem like the one, thanks! It's a lot with an ISA-486 board, a bunch of *other* RAM, Celeron 1100A, Duron 850, and possibly more stuff.
I did see it had a doomsday battery that'd need replaced and cleaned, but that's nothing I'm afraid of.
