First post, by cookertron
Hi Vogons,
I've got a 486 motherboard with a DALLAS RTC (DS1287A) fitted to it and it's dead. I've removed it but knackered the pins in the process.
Which chip does the DS1287A use, or is the chip used in the DS1287A actually the DS1287A?
Either way can the chip be purchased outside of the DALLAS RTC module so I can jam it into a socket and mount a button battery module on top of it?
Thank you
Asus P5A v1.06, Gigabyte GA-6BXDS, Soyo SY-5EMA (faulty), Viglen 486, Asus SP97-V
