First post, by Andry
Hello,
I'm fighting with a strange network behaviour on Windows 98 SE.
Configuration is:
Asus P5A V1.06 (BIOS 1011 b5)
AMD K62-533 CPU
512MB SDRAM
3DFX Voodoo3 2000 AGP
Sound Blaster AWE64 Gold ISA
Hitachi IC35L 80GB IDE HDD
RTL 8139 NIC PCI (3Com 3C905CA)
O.S. Windows 98 SE
Well, when I try to trasfer data thru network Win98 brutally reboot.
With RTL8139 NICs it reboot immediately. With a 3Com 3C905CA card it allow to transfer some megabytes of data (a random value), then reboot.
I tried to:
Reinstall Win98
Change PCI slot
Replace NIC drivers
Change NIC IRQ
Replace NIC
Any idea? Does someone experienced the same issue?
Thank you!
Andrea
Reply 1 of 1, by chinny22
If had to guess i would say hardware conflict. but you already changed the irq.
Maybe remove the soundcard (most likely conflicting device) and see if the network still crashes
