First post, by Intel486dx33
I wan to build an Intel Pentium 233mhz computer and I want it to be period correct.
Here is what I have so far.
Parts lists:
Intel chipset socket 5 motherboard.
Cache - 512kb
CPU - Intel Pentium MMX 233
RAM - EDO 64mb
Controllers - IDE onboard
Sound card - Turtle Beach Monte Carlo ISA ( Why, Because it is different and I want to try it ).
Video card - Not sure I want to try a ( nVIDIA GeForce FX 5500 FX5500 256 MB PCI 3D Video Card Graphics 2048x1536 ) or Matrox Millennium, or Other ?
Network card - 3com 3c509.
Case AT
OS - Win95
Reply 1 of 9, by Intel486dx33
Intel486dx33 wrote on 2020-03-27, 20:51:
I want to build an Intel Pentium 233mhz computer and I want it to be period correct. […]
Parts lists:
Cache - 512kb
RAM - EDO 64mb
Case AT
OS - Win95
Reply 2 of 9, by derSammler
Then your parts don't fit together at all. Also, you can't use an MMX on socket 5. You need dual-voltage socket 7 for MMX.
MMx 233 means mid-1997, so you should choose parts that were available in 1997 if you want to go period correct.
Reply 4 of 9, by aha2940
Intel486dx33 wrote on 2020-03-27, 21:08:
Okay, What Video card do I want ?
I assembled a PC just like yours (Socket 7 motherboard, Pentium MMX 233, 64MB EDO RAM) but used a voodoo3 PCI. I know that is not period correct, but the thing can run Quake II, Half-Life and even Unreal, which seems "unreal" to me.
In your case, for period-correct hardware and according to this link: https://www.neweggbusiness.com/smartbuyer/com … ards-1981-2015/ you would go with an nVidia RIVA 128 coupled with a voodoo2. Both PCI, obviously.
Reply 5 of 9, by computerguy08
It depends on what games/ software you want to run on it. If you want true 3D, then try S3 Trio64 + 3dfx Voodoo. That should be period correct, assuming that you are building around the Socket 5 motherboard. If, however, you want to go the 1997 way with the MMX chip, you should try aha2940's suggestion above.
Looking for a motherboard? You can find it in Ultimate Hardware 2019: http://www.win3x.org/uh19/motherboard/search
Join our UH19 Discord server here: https://discord.gg/HWWH7hsk2p
Reply 6 of 9, by Intel486dx33
Yeah, I was thinking about a Riva TNT too. I have some Voodoo PCI cards but they are not working. Oh wait I have one good Voodoo-3 3ooo Evil King PCI.
Can I just use that ?
What about Riva TNT-2 ?
Which card would work best with the Voodoo PCI adapter card ?
Reply 7 of 9, by imi
Voodoo3 and TNT2 are 1999 cards
voodoo2 is early 1998 so close enough I guess ^^
it doesn't really matter what card you get in addition to a voodoo1/2, the voodoo outputs it's own picture, but riva128 is a good fit for 1997, or any of the S3 cards 😀
Reply 8 of 9, by Intel486dx33
derSammler wrote on 2020-03-27, 21:02:
Oops, It must be a Socket 7 motherboard then.
Reply 9 of 9, by SodaSuccubus
You can if you manage to find a Pentium Overdrive MMX. They exist in both 160 and 200mhz variations.
Although its not worth it IMO. I have one i used for a while on a Compaq socket 5 machine, and the terribly slow S5 board crippled the MMX. Especally for win95+Voodoo gaming.
Their neat little collectables though.
Honestly, for a 1997 era MMX machine, i'd personally stick a Voodoo 1 and a AWE32 in there. Add any S3 Trio based card for the excellent compatibility. Top the rig up with 32 megs of ram (or 64 if you wanna go super ideal-world 97' 😜) and have a good time!
I would agree with an above poster though, that if you don't mind stretching the time period a little bit, add a Voodoo 2 instead.
V2+MMX 233makes a great flex win95/dos powerhouse! I had that config before i moved to a P3 and it was lots of fun 😁
