First post, by daibido1123
- Newbie
Hi all, so I am on the hunt for a 5.25 Floppy drive, but first I am trying to find out which one is the best option. I'm looking for a unit that does not need a cardboard spacer when not in use, that is double-sided read/write, that can read and write on all standards of data density floppies, and is of solid rugged construction that needs minimal maintenance and easy to clean if needed. An internal unit would be preferred, but an external unit is also an option. This is for a Pentium Socket 3 build.
Thanks all for your time.
Learning without thought is labor lost; thought without learning is perilous
Confucius
