First post, by aha2940
- Member
Hi guys
Today, I was testing some old hardware and found an SB16 (CT2950). It's crap; it has no OPL-3, it has the hanging note bug, etc. but I wanted to see if it worked just for the fun of it. So, I tried connecting it to my DOS machine, I installed the drivers for DOS, ran CTCM, etc. The card got configured for Address 220, IRQ 5, DMA 1, H DMA 7, P 300. Normal, I guess. The strange part is when I tried it:
- Tested it on duke nukem 3D setup, and while the music plays fine, there are no sound effects (no error, setup says it's playing them, but nothing comes out of the speakers).
- Tested it with Wolf3D, the music and simple sound FX play, but there are no digitized sounds (guards do not scream, shots make no sound). The game thinks it's playing them though, the option is enabled correctly in-game.
- Tried diagnose.exe, and while the synthesized music plays fine, the 8-bit and 16-bit digitized sounds do not play (no error though).
I played a bit with the mixer, but all volumes are at the highest setting. How can this be? any way to troubleshoot/fix this, or the card simply goes to the trash?
Thanks for the help.
