First post, by perhenden
The harddrive in my old PC1640 needs replacement, and I'm not sure which CF cards will work with the CompactFlash adapter for XT-IDE I bought.
My guess is that large cards , above 32MB and UDMA-enabled cards will not work. New/long-life cards within those specs may be hard to find or expensive.
Perhaps the XT-CF-LITE bios enables support for larger drives?
The XT-CF-lite FAQ says to make sure the card supports 8-bit transfer mode, and that most cards do, otherwise I can't find information on which cards are supported.
The CF spec requires that all compliant cards support 8-bit transfers in True-IDE mode, so hopefully that requirement will be easy to meet.
Recommendations for Compact Flash cards for this old 8086? Did you get a card larger than 32MB to work?
