First post, by abasak
So, I was putting together a SS7 system, and stuff went south. It seems like my board is fried, and I would like to at least try to diagnose it to learn something. I have a PCI POST Card on the way.
However, I am a bit confused as to what happened and where to start. I bought an old AT-case, with an old Seasonic PSU that the seller told me worked. He is legit, so I don't feel cheated, but maybe the PSU was faulty. This is what happened:
Note: the board is a PC-Chips M577 baby AT, with support for both AT and ATX PSUs.
I inserted the new CPU (switched from 6x86 to a K6-3 450mhz), set the jumpers to the correct clock speed, multiplier and of course voltage. I turned the system on. It booted fine, and I had it running in the case for a couple of hours. At one point it felt like static in the chassis of the case, but the mainboard was not touching anything it shouldn't touch, however I turned the computer off at the power switch. When I turned it on again 15-30 min later, nothing. Except for the CPU-fan spinning. No beeps from the speaker (which worked as I tested it).
What I have tried:
- Using a different ATX psu
- The video card works in another system.
- Have tried inserting only one stick of memory in slot 1, 2 or 3
- Have tried the 6x86 again (with correct jumpers), it just gets hot as does the K6-3.
- Booting without RAM or videocard to provoke a beep.
- AT keyboard only lights up when system is switched off
- Reset the CMOS.
- Checked for blown caps or chips, but nothing to see
Nothing works
What the hell happened? It worked, I turned it off, then turned it on again, literally the only thing I did. I didn't touch anything.
Second question: With a multimeter, is there anything I can do to diagnose the system? Or will I actually harm it even more?
Third question: Is there any chance of repairing such a system?
Bonus question: I don't like to throw out old tech, so is there anyway to safely test, if the PSU is faulty or is that a fools errand or outright dangerous?
Hope you guys can help, I am a bit depressed, really wished to have it running and enjoying my old games.
Reply 1 of 2, by Jorpho
PC-Chips is not exactly a reliable brand and you would probably be better off with something else in any case.
It might be useful to try to check the capacitors; some of them might be bad even if they aren't visibly blown.
abasak wrote on 2020-04-19, 19:06:
You can probably get an ATX PSU tester for a couple of bucks off eBay or something. Googling for "atx psu tester" (no quotes) should tell you lots.
https://www.youtube.com/watch?v=Ukcmp2EkYA0
