First post, by jackmtech
I have a Compaq 486 mobo that had no hard disk. I got a free hard disk from a friend, and that died on me in the middle of installing MS-DOS.
What good (and cheap) alternatives are there for these old and unreliable hard disks?
The mobo does not use LBA, instead it uses the old CHS formatting, so I don't know how well it would work with converters or solid-state media.
Reply 1 of 11, by mpe
CF 2 IDE adaptor + old <512MB CF card.
Cheap, fast and reliable.
There are other options too. But generally more expensive. I am using these in my systems:
848.88 KiB
Blog|NexGen 586|S4
Reply 2 of 11, by jackmtech
mpe wrote on 2020-04-23, 21:45:
Thanks for the reply, but I have this one nagging question, how would I set the CHS values for CF cards. Sorry if it sounds stupid, I'm new to the whole retro community.
Reply 3 of 11, by mpe
Use <512MB cards and you'll have no issues. BIOS should detect those automatically. If older with no detection you can detect on a newer systems and enter on the old. They'll all be the same.
512M card is usually 993 cylinders, 16 heads & 63 sectors.
Blog|NexGen 586|S4
Reply 4 of 11, by jackmtech
mpe wrote on 2020-04-23, 21:49:
Thank you! I just couldn't wrap my head around that .
Reply 5 of 11, by gdjacobs
The flash controller should emulate a user specified drive geometry. Just make sure C*H*S*512 is less than the storage capacity of your device (in bytes). As noted, you may have to obey specific limits on those parameters in order to fit under a hardware or BIOS limit.
https://www.win.tue.nl/~aeb/linux/Large-Disk-4.html
Reply 6 of 11, by jackmtech
So there is a bit of a problem. I can't find any 512MB CF cards that are reasonably priced. Will 1-4GB cards also work? I once saw someone put a 2.5GB hdd in one of these.
Reply 8 of 11, by jackmtech
imi wrote on 2020-04-24, 14:31:
you can get industrial SLC cards on ebay for ~$5 usually
I got one new from amazon for 8€ once cause I needed it quickly.
Yes, but I'm asking if it is possible to install more than 512MB, since the mobo does support more.
Reply 9 of 11, by brostenen
jackmtech wrote on 2020-04-24, 18:16:
Drive overlay is the answer....
Reply 10 of 11, by imi
well you just answered your own question I guess 😁
if your BIOS supports larger drives I don't see why it wouldn't be possible.
some vendors even give you the correct settings (Page 95):
https://www.verical.com/datasheet/sandisk-fla … 388-5045306.pdf
Reply 11 of 11, by mpe
If using DOS better to stay <512M. Bigger drives are possible with various workarounds, but you might face some compatibility issues, problems with booting, etc. Even when you can get it working you might be experiencing weird issues.
Such as I recently discovered that the default Windows 3.1 IDE driver (WDCTRL) can't enable 32-bit disk access on a hard drive with more than 1023 cylinders. I didn't know that.
Small cards sometimes came cheap with old digital cameras.
Blog|NexGen 586|S4
