First post, by egbertjan
I have a shuttle AV18E2 motherboard and the white ide connetor gives the following error no 80 pin conductor cable installed. I have already used several 80 pin ID cables, but nothing helps to get the message out. The hard drives that I connect to the white ide port are also very slow due to this message. The other blue ide port is working fine.
Who knows what I can do to fix this or is the motherboard broken?
I would like to use that motherboard to install Windows 98se to play old games.
