First post, by ZigZig
Hello,
I can get a K7S41GX from ASRock for 11 Euro. It's almost brand new, so I wanted to buy it for my Windows XP build. Later I found out that the nforce2 is deemed the best chipset, but I couldn't find a lot of information about the SiS 741GX. So did anyone use ASRock Socket A boards or any other motherboard with the SiS 741GX chipset?
Reply 1 of 3, by PC Hoarder Patrol
I still have a couple that I used, from around that period -
- Asrock K7S41GX
- Foxconn (Winfast) K7S41M01C
They were both fine for what they were intended; budget matx boards for spare XP systems. Don't recall any particular issues for that use, though what are you planning for your system?
Reply 2 of 3, by SPBHM
there are better chipsets for socket A, but it wasn't bad, the IGP is very basic, not for gaming, but the chipset itself is pretty standard for running a FSB333 AXP with single channel ram, agp8x on a budget,
I never thought it was slow, and it was very stable for me, when I used an ECS 741GX after years of using nforce2.
I'm not a fan of older asrock boards because I had issues with the ones I had, but many seem to have a good experience.
