If you're thinking about a Sinclair ZX Spectrum, all the schematics are on the service manuals but it can't be remanufactured anymore. The main reason is the ULA, that was a custom chip made by Ferranti not available anymore. But the good news is that it has been manufactured (at least) three times with public schematics:
- Superfo Harlequin: A board 100% compatible (hardware, software and form wise) with the original ZX Spectrum. On this page (sorry, spanish) you'll find schematics and board files to get your own boards made. The main differences with the original spectrum are that the ULA has been replaced with TTL chips, two 32K RAM chips instead of 16+ chips on original Spectrum and everything works at +5V (the DC-DC converter was known to fail and blow the lower RAM). Also, it has composite video output instead of RF and optional RGB video output. You can put this board into a standard ZX Spectrum or ZX Spectrum + case.
- Harlequin 128k (on the same page): A expansion board / mod for the original Harlequin boards. It only provides 128k memory, not the other (AY) features present on 128k Spectrums.
- ZX-Uno: This is a FPGA based board that was intended to be a ZX Spectrum clone... but may emulate other computers ("cores"). The most developed core is the ZX Spectrum one (emulating every Sinclair and Timex model), but there are MSX, Nintendo Entertainment System, Sega Master System and even a PC-XT core. The storage device is a SD card, and it has PS/2 connector for your keyboard and composite video output.
I've got a Harlequin on a ZX Spectrum + case, and worked with everything I've got. IMHO is the best clone, and being manufactured with old TTL chips means that everything (except the SMD optional RGB output) can be soldered without any special skills. The ZX-Uno is a interesting toy because can emulate many 8 bit computers... but it's not really a ZX Spectrum clone.
On the non-freely (without schematics) modern clones (russians manufactured lots of varying compatible clones on the 90's), you can get a ZX Next or a ZX Vega, but I wouldn't recommend it. After all, they're not real clones (like the Harlequin)... and the ZX-Uno is cheaper than both of them.
I'm selling some stuff!
