First post, by nuno14272
Hello everyone:
I've aquired a bunch of old computer sracp. In the pile there was some pieces i dont know whate are they..
Can You help ?
1) They appear to be some kinf of 8-bit add-on isa card.
https://imagehost.imageupload.net/2020/05/04/ … c4259f3bbff.jpg
https://imagehost.imageupload.net/2020/05/04/ … ca1f3837e8e.jpg
https://imagehost.imageupload.net/2020/05/04/ … 6c5443ceec1.jpg
https://imagehost.imageupload.net/2020/05/04/ … abcb0357cff.jpg
EDIT: A ACER PC500+ (NOT SHURE WITCH VERSION) - B,D, OR E
2) This appear to be some kind of 8-bit ISA XT floppy controler ?
https://imagehost.imageupload.net/2020/05/04/ … 8f67c0c3b1e.jpg
https://imagehost.imageupload.net/2020/05/04/ … 3f7a2fdc3c6.jpg
EDIT: A MFM CONTROLLER CARD... IT IS PART OF THE ACER 500+ ? WHO KNOWS)
3) Appears to be some Olivetti XT base system board with 640KB ram
https://imagehost.imageupload.net/2020/05/04/ … 2072901579a.jpg
https://imagehost.imageupload.net/2020/05/04/ … 9098fdc0abd.jpg
https://imagehost.imageupload.net/2020/05/04/ … 95e61a63083.jpg
https://imagehost.imageupload.net/2020/05/04/ … b25b55c6aa7.jpg
https://imagehost.imageupload.net/2020/05/04/5.jpg
https://imagehost.imageupload.net/2020/05/04/6.jpg
EDIT : IT'S A OLIVETTI PRODEST PC1 MOTHERBOARD...
Thank you.
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 1 of 3, by keropi
those are cards from an ACER 500 XT system IIRC, I had one at some point
the bottom one is the cpu card and the top one is the cga/fdd/serial/parallel card
both connect to an isa backplane
if I find my old pics I will post them
my thread about the system is here: Acer 500+ XT system but sadly pics are no longer working for the first couple of pages
2nd card is a MFM HDD controller
Reply 2 of 3, by Vynix
The 3rd board looks like to be from a Olivetti M24
EDIT: Nevermind. It looks like it has a NEC V40 CPU, so it can't be a M24 motherboard, as the M24 used a 8086.
Reply 3 of 3, by nuno14272
Vynix wrote on 2020-05-04, 15:07:
I figure it out..
it's a Olivetti PC1 motherboard
https://www.seasip.info/VintagePC/prodestpc1. … 4Ri08t8-iapj55I
Such a beautiful piece... damm.. wheres the rest of the computer ?
1| 386DX40
