First post, by peg
I had a crazy idea of using the turbo button on an AT case to switch between using different CPUs. I have this Cougar Alaris board and it has a built in CPU (386 class Blue Lightning) and also an additional socket 3 for adding an upgraded CPU (486 class or Pentium Overdrive). I believe you simply change a jumper to pick which cpu is used, but I'm not 100% sure since I've never used anything other than the built in CPU.
Could you not wire up a switch (or use the case turbo switch) to switch between using either CPU? Is this even possible and has anyone tried something like this before with this board or another "dual socket" board before?
Perhaps you could even use 2 switches. The existing turbo switch can still be used as is, for downclocking the cpu, and the other switch could be used to pick between the 2 different cpus. In this configuration, you'd have potentially 2 different CPUs each with 2 different speeds, netting a total of 4 possible running configs just from flipping a few switches.
Sounds pretty cool but I have no idea if it would ever work in practice. Even just switching between the 2 cpus by itself would yield vastly different performance in the case of going from the Blue Lightning to say the Pentium Overdrive 83, but having 4 different speeds would be pretty cool.
