First post, by user33331
- Member
Hello
Photo missing 1pc chip ?
(There should be 1pc tiny but long aluminum heat sink covering all 4pcs chips.)
Thanks
Hello
Thanks
These are IRF7822 MOSFETs. However, there are other photos on the net with 9800 Pros having only 3 installed, so I guess it came this way from the factory.
The 4th is on the removed heat sink 3/4 chips were unharmed but 1/4 ripped out.
- Originally "black screen" someone had ripped off the 2.2 Falco coil 0414 completely and I needed to remove the heat sink to be able to resolder the coil.
The original problem was the left coil but could this work with only 3/4 chips ?
RV350 ATI 9800 PRO 128mb. Hynix memory.
CGA-P988TVD.
Umm, no. Still wondering why the card only has 3 mosfets in the few photos on the net that show it with that tiny heatsink removed. Maybe the glue is stronger than the solder for that one 😁.
You could try and solder it back. Take care of the orientation, and check first with a multimeter if it isn't a dead short.
True. This won't move even how hard you try to remove it.
